Window and Door Renovation
BenCur
The renovation filter in the windows and doors tools offers greater flexibility.
It allows users to specify that only the window is being replaced while keeping the existing opening in the wall. It also allows users to choose to demolish only the shutters, not the entire window.
The same applies to doors: users can specify that only the panel is being replaced, not the frame. Alternatively, they can demolish the door but keep the existing opening in the wall, without having to create a new one if it already exists.
Possibilité d'avoir plus de flexibilité avec le filtre de rénovation dans les outils fenêtres et portes.
Pouvoir dire que c'est uniquement la fenêtre que l'on change et garder le trou dans le mur comme existant. Pouvoir dire que l'on démoli que les volet et non toute la fenêtre.
Idem pour les portes, pouvoir dire que l'on change que le panneau et non le cadre. Ou démolir la porte mais garder le trou dans le mur comme existant sans devoir remettre une ouverture à construire alors qu'elle existe déjà.
3 Comments
Noemi Balogh
@BenCur please translate your wish to English within' a week or we need to moderate it out. Thank you for your cooperation.
BenCur
The renovation filter in the windows and doors tools offers greater flexibility. It allows users to specify that only the window is being replaced while keeping the existing opening in the wall. It also allows users to choose to demolish only the shutters, not the entire window. The same applies to doors: users can specify that only the panel is being replaced, not the frame. Alternatively, they can demolish the door but keep the existing opening in the wall, without having to create a new one if it already exists.
k_archi
I would even add an option to chose what material/sandwich will fill opening after door/window is demolished. Now it is surrounding material, which could be poured concrete and I would like to fill the hole for example with bricks.
Status
Open
with 11/200 Votes 18.181818181818%
Wish details
Product
Labels
