Hello
Zones automatically extending into door and full height window recesses, is obscured by door/window fills. When I turn door/window fills off, the zone then shows in the recess, but also through the door frame. Can this be looked at please urgently?
I usually extend zones into recesses manually.
Many thanks
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
with 0 Votes
