centralization of label content by MVO
abdelaziz
a use case that could make our life easier, "managing the content of labels by MVO",
imagine that you have location plans at several scales and with specific information for each scale,
I place my labels in a specific layer with a specific code like <#byMVO> which would have the effect of browsing the MVO to determine the content of the label.
On the MVO side we will have a "Documentation" part that will allow us to manage all the documentary parts of the plan and in this part there will be tabs by documentation tool and a system of selection criteria, in the labels tab I choose the label contained in the layer and a Textual field I will be able to recall the automatic texts that I want for this combination of MVO.
This system remains generic and can be used and diverted for any specific use and need, the centralization of the content of the labels is a fundamental subject for a fast and fluid use
2 Comments
A21_Ma_Si
Yes, this would be very useful. This could work not only for Label, but for Zone Stamps, Door and widnow Stamps and similar.
I did script for myselft a new Window and door label that has the option to turn on and off the Marker Head (symbol + ID) by MVO. This way I can have a View showing the Marker Head of opening and one not showing it, but still showing the dimension of the opening.
abdelaziz
My wish is to give Archicad the ability to control auto texts through the MVO menu, for example adding a block of replacement text for dimensions to adapt to the scales of documents, another example for axes a part which will allow to modify axes according to the scales also, I want to Annotate my documents once and then adapt this annotation to the different documents I am tired of creating layers for each case
Status
Open
with 5/200 Votes 40%
