Archicad AI Visualizer
Discussions about Archicad AI Visualizer.
This group is dedicated to the experimental AI Visualizer for Archicad 27, which will reach End of Service on December 31, 2024.
The new AI Visualizer in Archicad 28 is now fully cloud-based, with advanced controls like creativity and upscaling. Click here for further details.
AI Visualizer - Startup AI Engine fails
Bjorntore
Hello!
Here comes another topic on AI Visualizer. I've searched up and down in "community", but I can't find a similar problem.
I have apparently managed to install the AI ​​correctly. But when I press "Start AI Engine" the prompt window flashes for a second, then disappears. Nothing more happens. When I press "generate" I get the message "sorry, we could not generate the picture. The AI ​​server is not available...". Anyone else run into this problem? For information, I run Intel core i9-13900HX 13th. generation, 64GB RAM and NVIDIA GeForce RTX 4090 GPU.
1 REPLY 1
Norbert Kucsma
Hi Bjorntore,
Thanks for the question.
Please contact your local support with a video about the error and the content of the Command Prompt window after starting the engine. We will investigate your issue.
Thank you,
Norbert Kucsma
Technical Support Engineer
