This group is dedicated to the experimental AI Visualizer for Archicad 27, which will reach End of Service on December 31, 2024.
The new AI Visualizer in Archicad 28 is now fully cloud-based, with advanced controls like creativity and upscaling. Click here for further details.
2023-11-21 05:17 PM
I am getting the following error when trying to complete step 5 of the install instructions
(5. Copy the files from the .dmg archive (20Gb) to the following locations:
o Copy the sd.webui folder into the Archicad folder.
o In the .dmg archive, locate the appropriate folder depending on your Mac’s
architecture – AppleSiliconMac for Silicon chips, IntelMac for Intel chips. From that)
"The Finder can’t complete the operation because some data in “diffusion_pytorch_model.safetensors” can’t be read or written.
(Error code -36)"
running AC 27, on MacBook Pro w/M1 16GB memory
Thanks
Solved! Go to Solution.
2023-12-01 05:59 PM
UPDATE - third time is a charm.
Re-downloaded the DMG - again - and this time it worked.
2023-11-23 01:17 PM
Hi Mark,
I am sorry to hear about the issue. Please check if you have enough free space on your Disk. Another possibility is that the downloaded file got corrupted, please delete the sd.webui file and try to download and install it again.
If it still fails check the suggestions on this site:
https://macpaw.com/how-to/fix-error-code-36
Don't hesitate to get in touch with your local support if you need further assistance.
Thank you,
Norbert Kucsma
Technical Support Engineer
2023-12-01 05:37 PM
Having the same issue. Did you get it resolved?
I've tried to re-download, and I have tried the dot_clean command as suggested in the link provided by Norbert. No luck.
Just out of curiosity, it this location/platform dependent? I'm running the USA version, and the visualizer alludes to the INT version.
2023-12-01 05:59 PM
2023-12-04 01:40 PM
Thank you, Yes the simple re-download did the trick for me as well. Now I just have to get around my computer running out of memory when running the Ai generator. This may require me to wait until our studio purchase new M3's at the end of the year 🙂
Thank you for your response!
2023-12-04 01:43 PM
Or... Just disable the start in High VRAM option as noted in other posts on the forum....
