Archicad AI Visualizer
Discussions about Archicad AI Visualizer.
This group is dedicated to the experimental AI Visualizer for Archicad 27, which will reach End of Service on December 31, 2024.
The new AI Visualizer in Archicad 28 is now fully cloud-based, with advanced controls like creativity and upscaling. Click here for further details.
First tries, how to diverge to a good design
Jeroen
I find that it is hard to steer the to a good result. Once you have something you like, but the rest is not there yet, there is no mechanism to keep parts of it. The next try can be totally different. For example, at some point the solar panels were right, but that changed again later. There is no way to keep the correct solar panel. I wish I could draw a circle around it and keep that.
I tried to highlight (blue) certain elements in Archicad, so I could give those elements a specific finish. But that has no effect.
Gardens and people are though in Archicad, but I could not add anything to it. Also I would like to replace a sphere with something else. That also does not work.
The Prompt strength did not give any better results for me.
AI Test 00005.pngAI Test 00008.pngAI Test 00003.pngAI Test 00009.pngAI Test 00002.pngAI Test 00010.pngAI Test 00006.pngAI Test 00001.pngAI Test 00004.pngAI Test 00007.png
1 REPLY 1
Norbert Kucsma
Hi Jeroen,
Thanks for the feedback.
The AI Visualizer is an experimental feature at the moment. The functions you are missing are indeed missing. It is not possible to select a part of the image and keep it with the rest of the image regenerated, also selecting specific elements and giving them special attributes (in prompt) do not work.
However, these are good ideas and we will consider them in the future.
Kind regards,
Norbert Kucsma
Technical Support Engineer
