Archicad C++ API
AC DEVkit 12 examples build error "windows.h" missing?
I have downloaded the add-on development kit for AC12. i have tried to build the examples with visual C++ 2005 express edition and i get the following error:
1>c:\Program Files\Graphisoft\API Development Kit 12.2156\Support\Modules\GSRoot\Win32Interface.hpp(34) : fatal error C1083: Cannot open include file: 'windows.h': No such file or directory
I have searched for this file "windows.h" file and i cant find it
can anyone help?
Thanks Mark
7 REPLIES 7
can anyone help?
Take a look at your Solution Properties - browse into the C/C++/Preprocessor settings. The setting "Ignore Standard Include Path" should be 'No'.
Ralph Wessel BArch
Central Innovation
I do not believe that the Windows SDK is part of the Express download. If Ralph's suggestion does not resolve things for you, you may have to follow the links on the Express-related and/or MSDN web pages for the SDK download. (You will not need MFC.)
Please post how how you resolve things.
AC 29 USA and earlier   â€¢   hardware key   â€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Girts Gaidels
I am using Visual C++ 2005 express for AC 12 DevKit without problems.
As Karl said, Windows SDK is not a part of the Express download. You need some extra steps after installation.
Look at links below for more info:
http://www.codeproject.com/KB/applications/FreeVS2005Win32.aspx
https://security-shell.ws/showthread.php?t=3612
http://msdn.microsoft.com/en-us/library/ms235626(VS.80).aspx
Regards,
Girts
Thank you for posting the links, Girts!
Thanks for the links will give it a go now cheers
Thanks for the help guys the examples are building now.
cheers,
Mark
That's good news, Mark. Thanks for confirming.
