Archicad C++ API
SOLVED!
AC24 how to change rectangle columns section width and height?
Boling1
I can create a rectangle column, but don't know how to change section width and height, AC24:
void Do_CreateColumn (void)
  API_Coord point;
  if (!ClickAPoint ("Pick a point", &point)) {
    return;
  API_Element element;
  API_ElementMemo memo;
  BNClear (element);
  BNClear (memo);
  element.header.typeID = API_ColumnID; // set as a column
  GSErrCode err = ACAPI_Element_GetDefaults (&element, &memo); //get current setting
  if (err != NoError) {
    ACAPI_WriteReport ("ACAPI_Element_GetDefaults (Column) has failed with error code %ld!", true, err);
    ACAPI_DisposeElemMemoHdls (&memo);
    return;
  element.column.origoPos = point;
  element.column.bottomOffset = -0.05;
  element.column.topOffset = -0.05;
  element.column.axisRotationAngle = 45; //rotate
  memo.elemInfoString = new GS::UniString("KZ-1"); //uset ID
  err = ACAPI_Element_Create (&element, &memo); //create the column
    ACAPI_WriteReport ("ACAPI_Element_Create (Column) has failed with error code %ld!", true, err);
  char buffer[65];
  sprintf(buffer, "%s%d", "Column Segment:", element.column.nSegments); //1 segment in fact
  MessageBox(NULL, buffer, "Grand", 0); //display how many segments
  //modify section width and height     ACAPI_CallUndoableCommand 进程中-----------------------------
  ????how to change the section width and height of this column ???
} // Do_CreateColumn
ArchiCAD 25
1 ACCEPTED SOLUTION
Solution
poco2013
Mentor
I had to go back and look at my notes and still didn't figure it out. I don't know how the define a segment column and a column without segments.
But you can use a single segment column by using the memo fields and set nsegments as 1;
 then use:
	element.column.nSegments = 1;
	memo.columnSegments[0].assemblySegmentData.buildingMaterial = ??;
	memo.columnSegments[0].assemblySegmentData.nominalHeight = ??;
	memo.columnSegments[0].assemblySegmentData.nominalWidth = ??;
	memo.columnSegments[0].assemblySegmentData.modelElemStructureType = API_BasicStructure; or ???
For more nsegments change the index of columnsegment in memo
Gerry
Windows 11 - Visual Studio 2022; ArchiCAD 27
2 REPLIES 2
Solution
poco2013
Mentor
 then use:
Gerry
Boling1
thank you very much,it works fine!
Great!
ArchiCAD 25
