Archicad C++ API
ACAPI_Automate returning REFUSEDCMD error
I'm calling
err = ACAPI_Automate(APIDo_CloseID, NULL, NULL, NULL);
from my menu handler with a new plan open from a template and it returns APIERR_REFUSEDCMD
Is there a way to close the current file?
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
Unfortunately you can't use APIDo_CloseID from an AddOn, it's not a public operation. That's why it was refused.
I don't know why do you need to close, but maybe the following function can help you:
ACAPI_Database (APIDb_CloseWindowID, API_WindowInfo* windowPars, NULL, NULL);
Best,
Tibi
Thank you.
The Document Management System I'm interfacing with has a close after checkin option which I was trying to honour.
However as the Addon is disabled if the file is closed I've decided to not honour the option.
Thanks again.
