Archicad C++ API
ACAPI_View_ReSetZoom linking is not possibel in AC28
Dinnye
I porting some addon to AC28.
I have linker error message.
error LNK2001: unresolved external symbol "int __cdecl ACAPI_View_ReSetZoom(short *)" (?ACAPI_View_ReSetZoom@@YAHPEAF@Z)
Thanks
Akos Somorjai
Thanks Dinnye!
For others: this will be solved in the devkit we issue from the final build. It doesn't cause any problems if you don't use that function.
Best, Akos
1 REPLY 1
Akos Somorjai
Thanks Dinnye!
Best, Akos
