API : HotlinkNode Element and database
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2008-12-17
03:38 PM
‎2023-08-04
02:49 PM
Doreena Deng
i'm trying since last month to write a plugin which load an external Hotlinked Module and place it on the project.
I'm near the end , i'v loaded the module, assigned it to an element but i don't succeed to place it on the project.
Here is my little fonction :
API_HotlinkNode myAPI_HotlinkNode;
GSErrCode err;
IO::Location location("c:\\test.MOD");
API_Guid myAPI_HotlinkNodeGuid;
API_Element element;
API_ElementMemo memo;
/******************************REMPLISSAGE DE LA STRUCTURE******************************************/
BNZeroMemory (&myAPI_HotlinkNode, sizeof (API_HotlinkNode));
//Charge le module en mode unique (define single story mode)
myAPI_HotlinkNode.storyRangeType = APIHotlink_SingleStory;
//Precise les que les extensions possibles sont :.pln, .mod, .plp or .2dl file. (define file type)
myAPI_HotlinkNode.type = APIHotlink_Module;
//Définie le fichier à charger (define file to load)
myAPI_HotlinkNode.sourceLocation = &location;
//definie l'étage comme étant l'étage -2
myAPI_HotlinkNode.refFloorInd = -2;
CHANSI2Unicode ("Module 1", GS::CStringLen, myAPI_HotlinkNode.name,API_UniLongNameLen, CC_Default, NULL);
/******************************FIN REMPLISSAGE DE LA STRUCTURE**************************************/
/********************CREATION DU GUID*************************************/
err = ACAPI_Database (APIDb_CreateHotlinkNodeID,&myAPI_HotlinkNode,NULL,NULL);
if (err != NoError) {
afficheMessage("HotlinkNode parameter is NULL or sourceLocation is NULL or invalid",err);
return err;
myAPI_HotlinkNodeGuid = myAPI_HotlinkNode.guid;
/********************MISE A JOUR DU CACHE*********************************/
err = ACAPI_Database (APIDb_UpdateHotlinkCacheID,&myAPI_HotlinkNodeGuid,NULL,NULL);
switch(err)
case APIERR_BADPARS:
afficheMessage("hotlinkNodeGuid parameter is NULL",err);
break;
case APIERR_BADID:
afficheMessage("hotlinkNodeGuid is invalid",err);
break;
default:
afficheMessage("APIDb_UpdateHotlinkCacheID",err);
break;
return err;
/******************PLACE LE MODULE LIE DANS LA DATABASE*******************/
err = ACAPI_OpenUndoableSession ("Place le module");
if (err == NoError)
BNZeroMemory (&element, sizeof (API_Element));
element.header.typeID = API_HotlinkID ;
element.header.index = 1;
err = ACAPI_Element_GetDefaults (&element, &memo);
if (err == NoError)
element.hotlink.type = APIHotlink_Module;
element.hotlink.hotlinkNodeGuid = myAPI_HotlinkNodeGuid;
err = ACAPI_Element_Create(&element, &memo);
if (err != NoError)
switch(err)
afficheMessage("The passed parameter is NULL; element",err);
break;
case APIERR_BADID:
afficheMessage("The element type is invalid, or the element type is not supported by the server application",err);
break;
case APIERR_BADDATABASE:
afficheMessage("The current database is not proper for the operation",err);
break;
case APIERR_REFUSEDPAR:
afficheMessage("The element->header.typeID parameter was incorrect. It might happen if you want to create something in a window not capable to display it, for example a wall in a section window. ",err);
break;
case APIERR_NOTMINE:
afficheMessage("The element was attempted to be created on a layer owned by someone else. Most likely to occur when working on documents in teamwork mode. ",err);
break;
case APIERR_LOCKEDLAY:
afficheMessage("The element attempted to be created was on a locked layer",err);
break;
case APIERR_HIDDENLAY:
afficheMessage("The element attempted to be created was on a hidden layer.",err);
break;
case APIERR_INVALFLOOR:
afficheMessage("The element->header.floorInd parameter is out of range.",err);
break;
case APIERR_REFUSEDCMD:
afficheMessage("The passed identifier is not subject to the operation.",err);
break;
default:
afficheMessage("ACAPI_Element_Create",err);
break;
return err;
err = ACAPI_Database (APIDb_RedrawCurrentDatabaseID,NULL,NULL,NULL);
if (err != NoError)
afficheMessage("APIDb_RedrawCurrentDatabaseID",err);
ACAPI_DisposeElemMemoHdls (&memo);
else
afficheMessage("ACAPI_Element_GetDefaults",err);
ACAPI_CloseUndoableSession();
else
afficheMessage("ACAPI_OpenUndoableSession",err);
if someone would know the thing i forgot to do, thank you in advance for your help.- Labels:
Add-On (C++)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-12-18 01:22 AM
atila-diffusion wrote:Is an error returned at any point in this function? If so, where, and which error code?
Central Innovation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-12-18 09:03 AM
not any error is returned, that's why I really don't know what is missing.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-12-18 10:45 AM
atila-diffusion wrote:Check the easy things first - have you checked the storey (floor) and layer applied? And what does the transformation matrix contain?
Central Innovation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-12-18 11:28 AM
Do I have to fill it like this :
element.hotlink.transformation.tmx[3] = 10; element.hotlink.transformation.tmx[7] = 4; double co = cos (0.52359877556); double si = sin (0.52359877556); element.hotlink.transformation.tmx[0] = element.hotlink.transformation.tmx[5] = co; element.hotlink.transformation.tmx[1] = -si; element.hotlink.transformation.tmx[4] = si;about the layer is it this :
element.header.layer = 1;
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-12-18 11:35 AM
It works thanks to you, had to fill the layer.
I thank you very much.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-12-18 12:15 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-12-18 12:21 PM
atila-diffusion wrote:Yes, you need a developer ID from Graphisoft to enable the add-on to work with the commercial version of ArchiCAD. Take a look at the information here:
Do you know if we have to ask for a validation to graphisoft before to sell a plugin, or to do something else?
Central Innovation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-12-18 02:08 PM
Thank you for all
