ReignBough
APIAny_NeigToCoordID with unknown error [SOLVED]
I called the ACAPI_Goodies function and it returned 0xffffe4a5.
~ReignBough~
ARCHICAD 27 INT (since AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
3 Replies 3
All I can add is that we use the function successfully and haven't seen that error code before.
Ralph Wessel BArch
Central Innovation
ReignBough
This is what I've done:
1. Create a wall 9000m high (storey height is 3000m); home storey is second floor.
2. Create 3 windows on the created wall; sill is anchored to storey ('Sill to Story X'); sill height is 200m.
When the API_Goodies(APIAny_NeigToCoordID) is called, two of these three windows returns 0x0ffffe4a5 on both APINeig_WindHole[0] and APINeig_WindHole[1].
~ReignBough~
ReignBough
Found a solution to this problem. It seems that when getting the coordinate of a neig of an element, you should be on the same storey of that element. What I did was when I encounter this error (0xffffe4a5), I have to change the current storey to the element's storey (using ACAPI_Environment(APIEnv_ChangeStorySettingsID)).
BTW, this error is GSErrCodes::Error = -7003 fond in Definitions.hpp.
~ReignBough~
