Learn more
APIDb_GetCurrentDatabaseID problem/bug?
I cannot find out which section database I am using on the open notification. I get this problem in both ArchiCAD 9 and ArchiCAD 7.
To replicate this problem I have a simple test. dbUnid and dbIndex are both set from a section that is in the drawing.
APIDatabaseInfo newDB;
memset(&newDB, 0, sizeof(APIDatabaseInfo));
newDB.typeID = APIWindSectionID;
#if ACNINE
newDB.databaseUnId = dbUnid;
#else
newDb.index = dbIndex;
#endif
err = ACAPI_Database(APIDb_ChangeCurrentDatabaseID, &newDB, nil);
// can use the section database ok
err = ACAPI_Database(APIDb_GetCurrentDatabaseID, &newDB, nil);
// now I cannot get the current database. err == noErr, but...
// newDB.typeID == APIWindSectionID
// newDB.index == 0
// newDB.databaseUnId.id1 == 0
// newDB.databaseUnId.id2 == 0
Is this a bug? I'd like to know what database I just changed to without having to remember myself.
Thanks,
Adam
4 Replies 4
Adam,
How about using APIDb_GetCurrentDatabaseID to tell you which one is active? E.g.
	API_DatabaseInfo dbase;
	ACAPI_Database(APIDb_GetCurrentDatabaseID, &dbase, 0);
Ralph Wessel BArch
Central Innovation
My problem is with APIDb_GetCurrentDatabaseID. It tells me that its a section database but I cannot tell which section because the index/id's are zero.
As a workaround I am now using a global variable to tell which database I last changed to.
Oops - didn't read the question properly
I've checked the instances where I use APIDb_GetCurrentDatabaseID and I get non-zero values. Perhaps the results are dependent on the context in which the call is made?
Ralph Wessel BArch
Central Innovation
Hoa Tu
Adam,
I use "ACAPI_Automate (APIDo_ChangeWindowID, &windowInfo, NULL);" instead to change to a section/elevation window. It seems working ok.
HTH,
Hoa
