2022-10-02 11:58 PM
Hello Everybody!
I'm experimenting with the ACAPI_Navigator functions. My question is why does included code part only find navigator items with type: API_StoryNavItem, API_PerspectiveNavItem and API_AxonometryNavItem?
GS::Array<API_NavigatorItem> possible_items;
possible_items.Clear();
GS::Array<API_NavigatorItem> found;
API_NavigatorItem nav_item;
nav_item.mapId = API_PublicViewMap;
for (Int32 type_ID = API_UndefinedNavItem; type_ID <= API_DrawingNavItem; type_ID++)
nav_item.itemType = (API_NavigatorItemTypeID) type_ID;
found.Clear();
err = ACAPI_Navigator(APINavigator_SearchNavigatorItemID, &nav_item, nullptr, &found);
ACAPI_WriteReport("TypeID: " + GS::ValueToUniString(type_ID) + " found: " + GS::ValueToUniString(found.GetSize()), true);
if (err == NoError && found.GetSize() > 0)
possible_items.Append(found);
}I want to find all the NavigatorItems in the PublicViewMap, but this function seems to ignore sections and elevations and all other than above mentioned types. What other parameters of nav_item need to be set to get all the NavigatorItems?
Any help is appreciated!
2022-10-17 06:27 PM - edited 2022-10-21 10:42 PM
Same here on both AC23 and AC26. No idea if that's intended (for whatever seemingly undocumented reason) or a bug.
Edit: FYI, I've worked around this issue by parsing the entire navigator map tree
