yahavsa
Accesses the "height of opening" in the dimension's text
Hello,
I'm looking for a way to access the height of opening in text of dimension info and add there some text (in addition to the text that already there).
Adding 3 pictures to show what I mean
Adding Configuration image, and before and after images
Thanks
Windows 11, Visual Studio 2019, ArchiCAD 26, C++
Hi Yahavsa,
I haven't tried it myself, but I took a look if it's possible at all.
There is a list of API_DimElem entries in the memo of dimension elements. (See API_Element_GetMemo docs)
Each API_DimElem has a API_NoteType member. There you can change some text which I think might be the place where you can change the dimensions text.
Let us know if that's successful in case you try it! 🙂
Bernd
Automating Archicad with Add-Ons, GDL-Objects & Python Archi-XT.com
