2020-02-16 10:26 PM - last edited on 2023-07-03 02:57 PM by Doreena Deng
Solved! Go to Solution.
2020-03-07 02:41 PM
'STR#' ID_MENU_STRINGS_NEW "Menu strings" { /* [ ] */ "Planersoftware 2.0" /* [ 1] */ "Erstelle neues Fenster oder Tür^32101" }But this way:
'STR#' ID_MENU_STRINGS_NEW "Menu strings" { /* [ 1] */ "Planersoftware 2.0" /* [ 2] */ "Erstelle neues Fenster oder Tür^32101" }
2020-03-09 10:06 AM
2020-03-12 02:29 PM
2020-03-13 07:22 AM
2020-03-13 09:33 AM
Martin wrote:Those aren't indices – they're just comments. The compiler ignores them, so they could contain nothing or not be there at all. We put them in as an easy visual check when referencing the menu items in code, i.e. ensuring the code aligns to the resources.
The indexes are the problem. It is not working this way:
2020-03-13 03:22 PM
2020-03-13 03:35 PM
'STR#' 32510 "Nested Menu" { "Main Menu" "Submenu" "Item 1" "Item 2" "Item 3" } 'STR#' 32511 "Single Item" { "Main Menu" "Item 1" }The single menu item and submenu above will both appear under the menu "Main Menu".
2021-06-23 12:46 AM
