AddOnAdmin
Hi guys,
Just upgraded my Addon development environment to AC15, but ran into some serious problems in regards to the AddOnAdmin utility. First of all, it seems to be missing completely in the OSX version of the Development Kit. Secondly, the Windows version AddOnAdmin.exe requires an external dll UsageLogger.dll, which can be found in the AC install directory, unfortunately my system is 64bit and there is no way to install the 32bit version, therefore there is a mismatch between the dll and AddOnAdmin.exe which is 32bit only. What is going on here?
Thanks in advance,
Regards,
Thomas
7 Replies 7
Akos Somorjai
Hello Thomas,
BimThomas wrote:
Hi guys,
Thanks in advance,
Regards,
Thomas
Here's a new version for you:
https://webftp.graphisoft.com/reupload.html?code=MKLDVP1320742302
Best, Akos
Thanks a lot Akos, this version of AddOnAdmin.exe runs smoothly, much appreciated.
Kind regards,
Thomas
stefan
When I try to launch AddOnAdmin on OSX Lion, it just goes away. I am using a fresh install (no prior OS nor Xcode installed) and use Xcode 4.
Archicad-user since 1998
my Archicad Book
Ralph Wessel
Works OK here, although versions prior to the one released by Ákos had ceased to work. I'd be wary of using Xcode 4 with the ArchiCAD API though - there may be subtle incompatibilities.
Ralph Wessel BArch
Central Innovation
stefan
Dyld Error Message:
Library not loaded: @executable_path/_GSSupport/UsageLogger.framework/Versions/A/UsageLogger
Referenced from: /API DevKit 15.2702/*/AddOnAdmin.app/Contents/MacOS/_GSSupport/DG.framework/Versions/A/DG
Reason: image not found
There seems to be a missing framework (UsageLogger) that is not found.
But I was able to copy this framework from the ArchiCAD.app Frameworks... and it seems to work now.
Seems a bug with the downloaded package.
my Archicad Book
Akos wrote:
Hello Thomas,
BimThomas wrote:
Hi guys,
Thanks in advance,
Regards,
Thomas
Best, Akos
Hi guys,
I'am have the same problem with the AddOnAdmin tool in my Windows 7 x64Bit, i want to start the AddOnAdmin.exe in the Developement Kit but it don't have the UsageLogger.dll and the link provided above doesn't work (i can't download the new version).
Anyone know a solution for the problem?
Thanks in advance,
Best regards,
peter_D
Akos Somorjai
peter_D wrote:
Akos wrote:
Hello Thomas,
BimThomas wrote:
Hi guys,
Thanks in advance,
Regards,
Thomas
Best, Akos
Hi guys,
Thanks in advance,
Best regards,
peter_D
You can download the ArchiCAD 16 API Kit now; it includes an AddOnAdmin that works well for older ArchiCAD versions as well.
Best, Akos
