Allow palette-using add-on to use FreeData
Hi!
I am currently implementing a palette inside my add-on, and have run into a new problem.
My Add-on now has a palette that can be opened / closed. So far, so good.
The problem is, during development, I cannot apply changes to the add-on and rebuild it, as it does not get unloaded when I close the palette.
In the "Control the Load unload mechanism" article, the following is said :
About FreeData : "Some operations (e.g. when an add-on has its own palette[...]) cause the add-on to stay in memory without calling this function."
And : "An add-on must be unloaded when [...], all the palettes have been dismissed, [...]."
So far, here are my "Init" functions (called separately through the code) and my "Closing" functions (called when the user closes the palette) :
Init functions :
// Initialising callback
DGModelessInit(ACAPI_GetOwnResModule(), 32400,
			ACAPI_GetOwnResModule(), PaletteCallback, (DGUserData)&pltctrl, true);
// Inside the callback, on DG_MSG_INIT :
ACAPI_RegisterModelessWindow(dialID, PaletteAPIControlCallBack,
			API_PalEnabled_FloorPlan + [...] + API_PalEnabled_Layout)
Closing functions :
if (pltctrl.dialID != 0 && DGIsDialogOpen(pltctrl.dialID))
		DGModelessClose(pltctrl.dialID);
if (pltctrl.dialID != 0)
	DGEndProcessEvents(pltctrl.dialID);
	ACAPI_UnregisterModelessWindow(pltctrl.dialID);
	DGDestroyModelessDialog(pltctrl.dialID);
	DGDestroyPalette(pltctrl.dialID);
Using the debugger, I made sure every of these functions were launched.
Did I miss something to unload my Palettes?
Thanks !
0 Replies 0
