2019-06-10
10:02 AM
2022-10-04
04:30 PM
Daniel Kassai
Solved! Go to Solution.
2019-06-10 10:37 AM
2019-06-10 10:37 AM
2019-06-10 10:58 AM
2019-06-10 04:31 PM
2019-06-11 09:11 AM
alexhajdu wrote:Right.
So basically you are saying ArchiCAD 22.5004 and SDK 22.3004 should work because the main version number is the same, right?
alexhajdu wrote:I'm glad that you solved it!
I'm on Windows. Yes, we have external DLL dependencies.
alexhajdu wrote:The example Add-Ons does not have valid MDID resource. Please run ARCHICAD in Demo mode to test the functionality of the example Add-Ons, because in Demo mode ARCHICAD does not care about the invalid MDID. Or you can change the MDID resource to a valid one.
What is interesting, the Dll_Test is also not working and I've got:This add-on cannot be validated. Please contact the distributor.
2019-06-11 09:20 AM
2020-04-01 06:41 PM
alexhajdu wrote:
Thanks, Tibor for the answer.
So basically you are saying ArchiCAD 22.5004 and SDK 22.3004 should work because the main version number is the same, right? I'm aware SDK 22 will not work with version 23, or 21 etc...
I've got the generic message:The file is an outdated Add-On that cannot be used with this ARCHICAD version.
