Archicad C++ API
Archicad does not load plugin
Emkave
Good evening everyone. I have stuck with one issue relating to loading plugins into archicad on windows.
It all went this way:
I had compiled my plugin with the correct plugin id defined in plugin's configuration file.
I used a valid certificate to apply a digital signature to the compiled .apx plugin.
I tried to load the plugin into archicad on another pc.
It did not load. It gave an error that the plugin is either outdated or not valid.
I wonder if I am missing another step to make the plugin to be loaded on another device.
What steps you took to make your plugin to be loaded in archicad on another PC?
1 REPLY 1
Emkave
EDIT: I am so sorry, however, the issue was found. Incorrect cmake arguments that were used on Mac and Windows. On windows I had to define one extra argument about whether or not the product was for release or debugging.
No need to response!
Setup info provided by author
