kristkun
APIERR_BADINDEX error when creating element using GDL object library index
Hello,
I'm currently exploring on Archicad API and GDL.
I'm trying to place/create GDL object from an imported library.
I am using the sample add-on template here:
https://github.com/GRAPHISOFT/archicad-addon-cmake
I'm currently using Archicad 26.
I imported a library with GDL (I just found online though its version is Archicad 29. But i can insert the object successfully in the ground floor)
I modified the Add-on sample, to create a GDL object when the custom menu was clicked.
I did follow this topic but I'm having issues whit the APIERR_BADINDEX error message when ACAPI_Element_Create() was called.
https://community.graphisoft.com/t5/Archicad-C-API/How-to-call-and-place-a-GDL-element-with-API-func...
After Create, an error was raised
As you can see, there is no error occurred when searching for the library part (I used the file name to search for the library index. I added a breakpoint before the create element is called)
Hope someone could help me with this.
Regards
7 Replies 7
kristkun
Just an additional info. I also tried adding the memo in the parameter (commented code) but the same error has been raised
Miha Nahtigal
I think you are missing ACAPI_CallUndoableCommand() scope.
BIMquants.comBETA - Quantities and Costs Estimation in Archicad - BETA testers needed.
kristkun
Hello,
I just tried adding this mentioned method but still raising the same error code.
(I'm hoping i did apply the method correctly though)
static GSErrCode MenuCommandHandler (const API_MenuParams *menuParams)
	switch (menuParams->menuItemRef.menuResID) {
		case AddOnMenuID:
			switch (menuParams->menuItemRef.itemIndex) {
				case AddOnCommandID:
						/*ExampleDialog dialog;
						dialog.Invoke ();*/
						API_LibPart		m_libpart;
						BNZeroMemory(&m_libpart, sizeof(API_LibPart));
						m_libpart.typeID = APILib_ObjectID;
						const GS::UniString fileName { "05 Basic 2D example 1 AC19.gsm" };
						GS::ucscpy(m_libpart.file_UName, fileName.ToUStr());
						GSErrCode m_err = ACAPI_LibPart_Search(&m_libpart, false, true);
						Int32 m_ParamsCount = 0;
						double a, b;
						API_AddParType** params = NULL;
						m_err = ACAPI_LibPart_GetParams(m_libpart.index, &a, &b, &m_ParamsCount, &params);
						API_Element	m_element ;
						BNZeroMemory(&m_element, sizeof(API_Element));
						// GDL Object type
						m_element.header.type.typeID = API_ObjectID;
						// Library index
						m_element.object.libInd = m_libpart.index;
						API_ElementMemo m_memo;
						BNZeroMemory(&m_memo, sizeof(API_ElementMemo));
						m_memo.params = params;
						m_err = ACAPI_CallUndoableCommand("Create GDL Element", [&]() -> GSErrCode {
							return ACAPI_Element_Create(&m_element, &m_memo);
						if (m_err != NoError) {
							return m_err;
					break;
			break;
	return NoError;
zaza95
HI! I'm having the same issue. Did someone found the root cause for this?
Thanks in advance
Hiromichi Shinkawa
Hi, I'd suggest you to check whether the value of element.header.layer is correct, it shouldn't be zero.
HTH.
zaza95
I have set the layer to 1, but I'm still facing the issue. Do you any other idea on the reason?
Thanks in advance
Hiromichi Shinkawa
Hi, then please add one command before you set the library index like below.
HTH.
API_Element	m_element;
// GDL Object type
m_err = ACAPI_Element_GetDefaults (&m_element, NULL);
// Library index
