poco2013
Mentor
Attribute index
I am trying to obtain the attribute index (Font) by typeID and name in the attribute header. ACAPI_Attribute_Search(...)
Can't figure out the code to set the name -- my 'C' is not so good.
The name can be set either by the attribute name[API_AttrNameLen] or *uniStringNamePtr;
What is the line code to set either --- attr.name = "Courier New" does not work nor attr.uniStringNamePtr = &uniString
pardon my ignorance of 'C'
Gerry
1 Solution
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
Here is an example for you (copied from Attribute_Test.cpp, part of the Attribute_Test example Add-On):
API_Attribute	attrib;
GSErrCode	err;
BNZeroMemory (&attrib, sizeof (API_Attribute));
attrib.header.typeID = API_LayerID;
strcpy (attrib.header.name, "2D Drafting - General");
err = ACAPI_Attribute_Search (&attrib.header);		/* search by name: index returned in header */
if (err != NoError) {
	WriteReport_Err ("Layer \"2D Drafting - General\" was not found", err);
	return;
But if you already have the name in a GS::UniString object, then I recommend you to search by using the uniStringNamePtr member:
short GetAttributeIndex (const API_AttrTypeID typeID, const GS::UniString& attributeName)
	GSErrCode	err;
	attrib.header.typeID = typeID;
	attrib.header.uniStringNamePtr = &attributeName;
	err = ACAPI_Attribute_Search (&attrib.header);		/* search by unistring name: index returned in header */
	if (err != NoError)
		return -1;
	return attrib.header.index;
// You can simply call this function:
GetAttributeIndex (API_LayerID, "2D Drafting - General");
Go to post
3 Replies 3
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
GSErrCode	err;
	return;
	GSErrCode	err;
	if (err != NoError)
		return -1;
Ralph Wessel
There is some nice example code bundled with the API that can be really when the documentation isn't completely clear. In this case, there is an example for ACAPI_Attribute_Search in the Attribute_Test project:
GSErrCode			err;
This particular case is looking up a layer, but the same principle applies for any attribute type.
Edit: I see Tibor beat me to it
Ralph Wessel BArch
Central Innovation
poco2013
Mentor
Thanks Ralph --That's what I thought -- But I was having trouble with the compiler. Tried it again this morning and all worked OK. Don't know what combination I must of been using late,late last night, but probably old eyes and bad fingers ?
Thanks again and I will compile and look at the attribute example.
Gerry
