Simon_Weinberger
Automated plugin registration for macOS installer
Hello,
we'd like to provide an installer for macOS that not only copies necessary files but also registers itself automatically, so that the user doesn't need to manually add the plugin using the Add-On Manager dialog. Our Windows installer writes directly to the registry (HKCU\SOFTWARE\Graphisoft\Archicad\Archicad <some version>\Add-On Manager) to register our plugin. What is the suggested way of doing something similar on macOS?
Thanks
Simon
1 Solution
Akos Somorjai
Hello Simon,
On macOS, you can find similar information in the
~/Library/Preferences/com.Graphisoft.AC 26.0.0 INT v1.plist
file, where ~ indicates the user's home folder, 26 is the version of AC, and INT is the 3-letter language code.
Best, Akos
Go to post
Akos Somorjai
Hello Simon,
Best, Akos
