Erenford
[BUG?] AC22 Popup Ctrl on ListBox not appearing after resize
Greetings, I've been updating addons to AC 22 and found out that the Popup Ctrl appears when I set it on the List Box tab field, but disappears and no longer appeared after I resized the dialog (and thus the ListBox, its column and the Popup Ctrl).
After further testing I pinpointed the problem to Popup Ctrl no longer usable if you resized it. Even if you resize it right after DGAppendDialogItem on DG_MSG_INIT, it doesn't appear when you set it on the tab field.
I tried replacing it with a Button or Edit Ctrl and it doesn't have this problem, I can resize it and I can still use it on List Box tab field.
FYI I'm using palette dialog and no class just the DG functions
1 Solution
Erenford
Sorry my bad, I found the source of the problem:
On DGAppendDialogItem() for Popup-Ctrl:
Before (AC 21 and below) -> itemSubType = NULL (no errors, no problem)
Current (AC 22) -> I tried filling up itemSubType with an appropriate height (right now the Y size of Popup-Ctrl)
It now works and no longer disappear when resizing.
Go to post
1 Reply 1
Erenford
