Archicad C++ API
BUG in API? Do_Dimensions_Test not work with column
kuvbur
When run Do_Dimensions_Test function from the Element_Test example, the dimensions attached to the column disappear or change the anchor point. The column is made with a complex profile. Tested in AC25 and AC26.
How to solve a problem?
Structural engineer, developer of free addon for sync GDL param and properties
kuvbur
It seems that the problem occurs because the dimensions of the column do not have base.inIndex (always equal to 0)
There are several similar questions on the forum, but they are all unanswered -
https://community.graphisoft.com/t5/Developer-forum/How-can-I-get-apineig-colu-1-2-3-4/m-p/327973
https://community.graphisoft.com/t5/Developer-forum/How-to-create-assosiative-dimensions/m-p/331099
https://community.graphisoft.com/t5/Developer-forum/Get-coord3D-Neig-of-Column-by-C/m-p/342498
kuvbur
After update to 7000 bug still here 8(
