POTS
Bug ? Archicad 25 freezes when moving object imported from rhino
Hello,
As the title suggests, Archicad 25 freezes when moving object imported from rhino. is this going to be fixed at a certain point ? we cannot continue our work with a program that doesnt work, we are stuck. Also we can forget about this rhino to Archicad 'live' connection which 99% of the time crashes. Is there a plan to take it seriously or we should just avoid connecting rhino to Archicad in any way ?
greetings.
AC 25 NED 6000 | WIN 11 | i9 + 32GB + RTX 2080TI
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hello,
Thank you very much for the report and I am very sorry for the experience!
To my knowledge, the connection freezes if you try to bring a big object into Archicad from Rhino through the connection. For that purpose, saving the object as 3DM and import it into Archicad is a better solution.
I'm wondering if this is what you are having trouble with?
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
