GDL
Import .3dm model - edit objects all at once
Charles C
Hi community,
I was wondering if it is possible, once you imported a .3dm (Rhino) model into your Archicad (via merge from file) to Edit all of its objects (automatically converted into GDL) at once ?
I would like to select them all (more then 300 object in my .3dm imported file), and select their floor plan display to "overhead all" instead of projected.
Thanks
CC
1 REPLY 1
Is this Floor Plan Display setting in the Object Dialog after you select an Object converted from a Rhino geometry in Archicad? Because then you can just select all Objects and change their setting in a single step.
Or, is this some other setting during 3DM import?
