a week ago
- last edited
Wednesday
Hi community,
I was wondering if it is possible, once you imported a .3dm (Rhino) model into your Archicad (via merge from file) to Edit all of its objects (automatically converted into GDL) at once ?
I would like to select them all (more then 300 object in my .3dm imported file), and select their floor plan display to "overhead all" instead of projected.
Thanks
CC
Wednesday
Is this Floor Plan Display setting in the Object Dialog after you select an Object converted from a Rhino geometry in Archicad? Because then you can just select all Objects and change their setting in a single step.
Or, is this some other setting during 3DM import?
