Archicad C++ API
C++ add-on
Norik
Hey everyone!  I'm trying to develop an add-on for archicad 26, I've downloaded devkit 26, vs code, archicad 26(demo version), cmake, and python. I tried to do the exact same thing from here: https://github.com/GRAPHISOFT/archicad-addon-cmake but after generating the project with the cmake list provided I encountered a problem with inclusions of "APIEnvir.h", "ACAPinc.h", "ResourceIds.hpp", "DGModule.hpp".
I'm new to c++ and archicad, so there may be some things I did not understand properly.
If there are video materials or ready example add-on somewhere on github, I would be more than happy to have a look.
Thanks in advance!
1 REPLY 1
Joel Buehler
haha so many newcomers. love it 😃
when the inclusions dont work, you have to asume that the cmake creation process did not went trough.
i made a little step by step guide if you work with windows.
if you need help to bake the perfect cmake command, just write
https://community.graphisoft.com/t5/Developer-forum/developing-an-add-on-on-c/td-p/388005
i also had to start with c++ for the plugin development. a few tipps:
- test out low level stuff in a little console application,  easy stuff with objects and classes etc.
- realy realy check out the examples, they are very helpfull. look specially on the style of those. some have a very c-heavy coding style, others are more in line with java & c# i found the one with a high level coding language style the most usefull.
- it helped me a lot go trough examples like the maze generator step by step and comment evrything they do in my own words
hope that helps a little
