Call a module file with a button
Hi all,
I use "APIDo_SaveAsModuleFileID" for save a module selection in a file.
Now i want to call this file on a story. I don't find the function like "APIDo_OpenModuleFile".
If someone know how to do this…
Thanks
Regards.
1 Reply 1
Tibor Lorantfy
you can load a module file as a hotlink with APIDb_CreateHotlinkNodeID.
When hotlink was successfully created, you can place a hotlink instance with ACAPI_Element_Create using hotlink's GUID.
Regards,
Tibor
