We value your input! Please participate in Archicad 28 Home Screen and Tooltips/Quick Tutorials survey
2024-10-01 10:21 AM - edited 2024-10-01 10:47 AM
Can't get the two ids of the column element, only the GUID
2024-10-04 03:24 PM
OK I've completely misunderstood you before. Now I don't think you were looking for the Element ID property value. So forget what I said before.
Now to your actual problem: Not sure what the other GUID is for. How many GUIDs do you get when you add no element to the project?
a month ago
I think I can talk about my practical problems from another direction. When I add a column or a beam to a 3D scene, how to directly obtain their geometric information, such as vertices and surfaces?
4 weeks ago
I've used the ModelAccess API before for something similar. It's not very comfortable to use, but worked in my case. Also unfortunately the examples for it are a bit scarce.
I think the ModelerAPI you've used might be the newer iteration of the interface. But I've not used that yet and I'm really not sure about it's application.
Hope that helps.
4 weeks ago
Ok, I will find a suitable solution according to the direction you provided. Thank you very much.
