Changing drawing bounds doesn’t work
Hello
I am trying to change drawing bounds (element.drawing.bounds), but it doesn’t change. I am able to change other things in the drawing but not the bounds..
Thanks in advance.
8 Replies 8
Does changing the scaling ratio work?
Ralph Wessel BArch
Central Innovation
Drawingscale and parentoriginalscale are both output only.
Ratio works but changing only the drawing size and not bounds of the drawing - so I have to update / change bounds myself.
What happens when you change the ratio? If the bounding box doesn't change, does that mean the drawing is cropped when it expands or sits far within the bounding box when it contracts?
If so, there is a flag (isCutWithFrame) to indicate the drawing is cropped to the bounds – unsetting that might make the bounds automatically adjust. Alternatively, you might need to specify the bounds by defining the bounding polygon (poly + polygon memo).
Ralph Wessel BArch
Central Innovation
First question - yes
Changing ratio only works when first setting iscutwithframe as true and then false (doing ACAPI element change twice, first time with iscutwithframe=true and then iscutwithframe=false)
it doesn't
Yep. Anyone knows how to do that please?
Does anyone have an idea? My goal is to do the “update” action of layouts/drawings by code, or to change drawing bounds.
Thanks in advance!
I was also unable to change element.drawing.bounds. It just didn’t change..
Thanks in advance!
So I found the ApiDB_CheckDrawingStatuisID. Is there a function that’s actually changing the status (updating the drawing instead of just checking if it’s updated)?
