Code to do SAVE AS operation
Hi
Is there a function to do a SAVE AS operation?
I have found the Save function but I need to save the opened Archicad to be a different name.
3 Replies 3
Bianca wrote:
Hi
Yes there is.
static void		Do_Save_Plan (void)
	GSErrCode	err;
	err = ACAPI_Automate (APIDo_SaveID, NULL, NULL);
	if (err != NoError) {
		char msgStr[256];
		sprintf (msgStr, "Error in APIDo_SaveID: %d", (int) err);
		ACAPI_WriteReport (msgStr, true);
	return;
}		// Do_Save_Plan
// Save the current plan into a picture
static void		Do_Save_TiffFile (void)
	API_FileSavePars		fsp;
	API_SavePars_Picture	pars_pict;
	GSErrCode				err;
	BNZeroMemory (&fsp, sizeof (API_FileSavePars));
	fsp.fileTypeID = APIFType_TIFFFile;
	IO::Location folderLoc;
	API_SpecFolderID specID = API_UserDocumentsFolderID;
	ACAPI_Environment (APIEnv_GetSpecFolderID, &specID, &folderLoc);
	fsp.file = new IO::Location (folderLoc, IO::Name ("PictTest.tif"));
	BNZeroMemory (&pars_pict, sizeof (API_SavePars_Picture));
	pars_pict.colorDepth = APIColorDepth_256C;
	pars_pict.dithered   = false;
	pars_pict.view2D     = true;
	pars_pict.crop       = true;
	err = ACAPI_Automate (APIDo_SaveID, &fsp, &pars_pict);
		char msgStr[256];
		sprintf (msgStr, "Error in APIDo_SaveID (pict): %d", (int) err);
	delete fsp.file;
	return;
}		// Do_Save_TiffFile
// Save the current plan to an IFC file
static void		Do_Save_IfcFile (void)
	API_SavePars_Ifc	pars_ifc;
	GSErrCode			err;
	fsp.fileTypeID = APIFType_IfcFile;
	fsp.file = new IO::Location (folderLoc, IO::Name ("IfcTest.ifc"));
	BNZeroMemory (&pars_ifc, sizeof (pars_ifc));
	pars_ifc.subType = APIIfc_2x3;
	err = ACAPI_Automate (APIDo_SaveID, &fsp, &pars_ifc);
		char msgStr[256];
		sprintf (msgStr, "Error in APIDo_SaveID (Ifc): %s", ErrID_To_Name (err));
	delete fsp.file;
	return;
}		// Do_Save_IfcFile
// Save the current plan to an Pdf file
static void		Do_Save_PdfFile (void)
	GSErrCode			err;
	fsp.fileTypeID = APIFType_PdfFile;
	fsp.file = new IO::Location (folderLoc, IO::Name ("PdfTest.pdf"));
	err = ACAPI_Automate (APIDo_SaveID, &fsp, NULL);
		char msgStr[256];
		sprintf (msgStr, "Error in APIDo_SaveID (Pdf): %s", ErrID_To_Name (err));
	delete fsp.file;
	return;
}		// Do_Save_PdfFile
By the way you can look at Automate_Functions example
Thank you for your response.
However I am looking for a 'SAVE AS' function, I believe this one from the examples is just a 'SAVE' function
ReignBough
Not sure about this, but have you tried changing the API_FileSavePars.file to your desired "different" file name?
~ReignBough~
ARCHICAD 27 INT (since AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
