Converting UniString to string with Hebrew characters doesn’t work
Hello
I am trying to convert a UniString which has Hebrew characters in it (it looks good on debug), to const char or string,.
The UniString with Hebrew characters looks good but the conversion (.toxstr().get()) kills the Hebrew characters (they become jibrish).
That’s a real problem for me.
Please help!
Thanks
1 Solution
Tibor Lorantfy
I recommend you to use IO::FileSystem::Copy method instead:
#include "FileSystem.hpp"
IO::Location from (uniString1);
IO::Location to (uniString2);
IO::fileSystem.Copy (from, to);
It's easier than converting
Go to post
3 Replies 3
Tibor Lorantfy
Why do you want to convert the GS::UniString object to const char* or std::string?
Could you show us please the relevant part of your code?
Regards,
Tibor
Regards,
Tibor
Hi
I want to use CopyFile (c++ function) and it only works with string..
Tibor Lorantfy
