Crash for GetOrganizationIds in DEBUG builds (linked to ACAP_STATD.lib)
Hi!
I've come across this weird issue where Archicad crashes in my Debug builds when I request the OrganizationId of the user. I was able to pinpoint that the issue only happens when linking to ACAP_STATD.lib. If I use ACAP_STAT.lib (as I usually do only for Release builds) then the issue doesn't happen.
And I've further figured out that the return value of GetOrganizationIds() is not properly initialized in ACAP_STATD.lib. Here's some example code to show this:
auto gsid = ACAPI::CreateGSIDObject ();
if (gsid.IsErr ()) { return APIERR_GENERAL; }
auto maybeOrganizationIds = gsid->GetOrganizationIds ();
if (maybeOrganizationIds.IsErr ()) { return APIERR_GENERAL; }
// For AC27 & AC28 this outputs the following depending on linked ACAPI library
// ACAP_STAT.lib: "Initialized: 1"
// ACAP_STATD.lib: "Initialized: 0"
ACAPI_WriteReport ("Initialized: %d", true, maybeOrganizationIds.Storage ().initialized_);
In AC26 the same crash happens with ACAPI_Protection_GetGSIDOrganizationIds().
I've only tested on Windows so far.
Here's a summary table of my results:
Archicad API DevKit Version Linked To ACAP_STAT.lib Linked To ACAP_STATD.lib
26.7000 Win
no crash crashes
27.6003 Win no crash crashes
28.3001 Win no crash crashes
Can someone else reproduce this behavior or even knows a fix?
Best,
Bernd
Automating Archicad with Add-Ons, GDL-Objects & Python Archi-XT.com
1 Solution
Viktor Kovacs
The issue happens because the ITERATOR_DEBUG_LEVEL values of Archicad and the Add-On are different (Archicad is a final build, the Add-On is a debug build). This cause problems only if there are standard library containers on the called interface.
Because of this issue it's not recommended anymore to use ACAP_STATD.lib, and you also need to set the ITERATOR_DEBUG_LEVEL to 0 in your Add-On.
Please see this change on how to update your configuration:
https://github.com/GRAPHISOFT/archicad-addon-cmake-tools/commit/243d12edee1cd3b5ddd90937ca88dbf665be...
Go to post
3 Replies 3
Viktor Kovacs
Thanks Viktor for the detailed answer!
I'm a bit concerned that having to switch to MultiThreadedDLL & ACAP_STAT.lib also in Debug builds might interfere with the debug information and thus in my debugging workflow. But I'll give it a try and report back.
I've tested and the normal debugging workflow seems not to be affected 🙂 So all good! I'll just change all my Add-Ons to these settings.
Thanks again @Viktor Kovacs!
