Archicad C++ API
Create a Drawing from a file?
Erenford
How do you link a drawing to an external file? On ArchiCAD you just click on "an external source" -> click "Browse" -> choose the file. How do you do this with the API?
What are the requirements? Creating a drawing from a view is simply by copying the view's guid to drawing.drawingGuid and you're done, is it the same with a file? I've looked into API_DrawingLinkInfo but it seems there is only a "Get" function and no "Set".
Thanks.
1 REPLY 1
Hoa Tu
Thanks.
Hi All,
I am also interested to know if there is anyway to set/relink an external file of a drawing using API.
I am using ArchiCAD 21.
Thanks,
Hoa
