Archicad C++ API
SOLVED!
Create and then undo several elements together
yahavsa
Hello
I create several elements using the ACAPI_Element_Create function in a "for" loop. After that, I'm trying to undo it (using ctrl+z) and right now it undo each element one by one (For example, if I create ten elements in my function and I want to undo it, I have to press ctrl+z ten times).
I'm wondering if there is a way so I can ctrl+z all the elements that I just created all together by using ctrl+z ONE time?
I did try to use the ACAPI_Database_StartClippingSession() function before the "for" loop and then use the ACAPI_Database_StopClippingSession() function at the end of the "for" loop, but it didn't work for me
Windows 11, Visual Studio 2022, ArchiCAD 27,  C++
1 ACCEPTED SOLUTION
Solution
Viktor Kovacs
When you do modifications in Archicad you always need to wrap your changes in a ACAPI_CallUndoableCommand call. Everything happens inside the call will be undo-ed in one step.
The code should be something like this:
ACAPI_CallUndoableCommand ("Create Walls", [&] () -> GSErrCode {
     // create as many walls as you need
     return NoError;
1 REPLY 1
Solution
Viktor Kovacs
     return NoError;
