Archicad C++ API
Creating User Interface in Add-Ons
Nayan
Hello, I am new to ARCHICAD. Need to do some automation task in ARCHICAD 24 using the Add-Ons. For this I need to create a user interface (Text box, Dropdown etc. to interact with the user). For this reason I have come to know that we can use Visual c++ MFC for the interface creation.
Is it possible to use the MFC project with the Add-Ons(Have gone through the Add-Ons template for CMake)?
Or if there is anything better for this please suggest me.
Maybe you should take a look of "DG_Test" example in ArchiCAD API SDK.
Or see also "Hello World 2" or "Maze Generator" blog in ArchiCAD API page.
Nayan
Thanks a lot for the suggestion. Gone through the mentioned resource and helped me a lot.
