Archicad C++ API
Curtain Wall Geometry
I need to create 3D representation of curtain wall for export. I know that curtain walls in AC consists of segments, frames, panels, junction and accessories.
Here is couple of questions:
What is easiest way get access to curtain wall geometry?
How get access to curtain wall components using API_CurtainWallID?
API_CurtainWallType           curtainWall;
API_CWallSegmentType          cwSegment;
API_CWallFrameType            cwFrame;
API_CWallPanelType            cwPanel;
API_CWallJunctionType         cwJunction;
API_CWallAccessoryType        cwAccessory;
Ralph Wessel
Mentor
Take a look at the documentation for ModelAccess - there are methods to access all the 3D primitives.
Alternatively, the (older) methods described in the 3D Manager documentation can be used too.
Ralph Wessel BArch
Active Thread Ltd
Thanks a lot!
I managed to get curtain wall geometries quite easily. The 3D_Test.c example was useful.
Why in the 3D_Test.c example (see. code) there is degenerate check for frames too? This check seems to fail always for frames. I used the check only for panels.
// frames
GSSize nFrames = BMGetPtrSize (reinterpret_cast<GSPtr>(memo.cWallFrames)) / sizeof (API_CWallFrameType);
for (idx = 0; idx < nFrames; ++idx) {
	err = ACAPI_Database (APIDb_IsCWPanelDegenerateID, &memo.cWallFrames[idx].head.guid, &isDegenerate);
	if (!isDegenerate) {
		elems.Push (memo.cWallFrames[idx].head);
	} else {
		GS::Guid guid = APIGuid2GSGuid (memo.cWallFrames[idx].head.guid);
		WriteReport ("Degenerate Frame: %s", (const char*) guid.ToUniString ().ToCStr ());
// panels
GSSize nPanels = BMGetPtrSize (reinterpret_cast<GSPtr>(memo.cWallPanels)) / sizeof (API_CWallPanelType);
for (idx = 0; idx < nPanels; ++idx) {
	err = ACAPI_Database (APIDb_IsCWPanelDegenerateID, &memo.cWallPanels[idx].head.guid, &isDegenerate);
		elems.Push (memo.cWallPanels[idx].head);
	} else {
		GS::Guid guid = APIGuid2GSGuid (memo.cWallPanels[idx].head.guid);
		WriteReport ("Degenerate Panel: %s", (const char*) guid.ToUniString ().ToCStr ());
