DGAppendDialogItem broken?
Hi, I am wondering what you need to do to get DGAppendDialogItem to create an item on a modal dialog. I've tried calling it inside and outside DG_MSG_INIT, tried creating different types of controls, and tried on pre-made dialogs and DGBlankModalDialog. And I haven't yet been able to get a new control to appear.
Is there something special you need to do to get this function to work?
Thanks
3 Replies 3
For example, the following code displays a blank dialog box (the button is not added).
static short DGCALLBACK	TestDlgCallBack (short message, short dialId, short itemId, DGUserData /*userData*/, DGMessageData /*msgData*/) {
	switch (message) {
		case DG_MSG_INIT:
				short newItem = DGAppendDialogItem (dialId, DG_ITM_BUTTON, DG_BT_TEXT, NULL, 5, 5, 20, 20);
				DBPrintf("new item %d added\n", newItem);
			break;
		case DG_MSG_CLOSE:
			break;
		case DG_MSG_CLICK:
			switch (itemId) {
				//case 2: // Close button
				case DG_CLOSEBOX:
					return(1);
					break;
				default:
					break;
		default:
			break;
	return 0;
void openTestDlg() {
	DGBlankModalDialog (200, 200, DG_DLG_HGROW | DG_DLG_VGROW, 0, DG_DLG_THICKFRAME, TestDlgCallBack, NULL);
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
Hi paulk,
After using DGAppendDialogItem, you should call DGShowItem to make the new item visible:
  // add new item:
short newItem = DGAppendDialogItem (dialId, DG_ITM_CHECKBOX, DG_BT_TEXT, 0, 206, 7, 60, 18);
  // set font, text and others:
DGSetItemFont (dialId, newItem, DG_IS_EXTRASMALL);
DGSetItemText (dialId, newItem, "NEW");
  // make it visible:
DGShowItem (dialId, newItem);
Best,
Tibi
Thanks Tibi
That info should be added to the API documentation.
Paul
