ViloFR
DGSetDialogTitle - parameters issue
I keep working on my ArchiCAD addon from Delphi, and I'm facing an issue.
According to the SDK documentation, the function DGSetDialogTitle is declared as :
void DGSetDialogTitle (short dialId, const char* title);
In the header file DG.H, it is declared as :
void DGSetDialogTitle (short dialId, const GS::UniString& title);
1. What is the right declaration in ACAP 18 ?
2. If this is the second one, because UniString is exported as a class, it is not possible with any other language appart from C to instantiate it.
How am I supposed to call this function ?
In other words, is ArchiCAD addon dev reserved to those who are using the same language, EDI, and specific version of the EDI (otherwise ACAP_STAT.LIB is not linkable) as Graphisoft ?
Thanks 🙂
Ralph Wessel
The interface will always be correct. The documentation probably isn't entirely up to date (it's a tough job).
I'd recommend sticking to the GS guidelines of C/C++. It may be possible to use other languages to some extent, but I think you face an almost impossible task making the UI work properly.
Ralph Wessel BArch
Central Innovation
ViloFR
Bad news ... But thanks a lot for your answer.
