2026-01-13 09:16 AM - edited 2026-01-13 09:17 AM
Hi all,
I have an object that you can load standard AC windows into with all of their associated settings. My current issue is that what settings are available depends on the variables iWindowClass and iWindowType which when change to or from any of the Multisash options (iWindowType 42 or 43, iWindowClass 8 ) breaks the object by making optypeIDArray[CasementID] in the GeneralWindowUnit macro return an invalid result... I tried setting iWindowClass automatically based on the iWindowType input, but it only returns 8 for some reason...
IF GLOB_MODPAR_NAME = "iWindowType" then
IF iWindowType <= 9 then iWindowClass = 1
IF 10 <= iWindowType <= 15 then iWindowClass = 2
IF 23 <= iWindowType <= 25 then iWindowClass = 3
IF 26 <= iWindowType <= 28 then iWindowClass = 4
IF 16 <= iWindowType <= 17 then iWindowClass = 5
IF 29 <= iWindowType <= 39 then iWindowClass = 6
IF 45<= iWindowType <= 48 | 100 <= iWindowType <= 102 then iWindowClass = 7
IF 42 <= iWindowType <= 43 then iWindowClass = 8
IF iWindowType = 99 then iWindowClass = 99
PARAMETERS iWindowClass = iWindowClass
endIF
Ling.
VALUES{2} "iWindowType" 1, "WIN_W1",
2, "WIN_WDoubleSash",
3, "WIN_W2",
4, "WIN_W2Sidelight",
5, "WIN_W3",
6, "WIN_W32Sidelights",
7, "WIN_W32Sidelights2",
8, "WIN_WVariable",
9, "WIN_WVariableDoubleSash",
10, "WIN_HistoricWindowSingle2",
11, "WIN_HistoricWindowSingle",
12, "WIN_HistoricWindowDouble",
13, "WIN_HistoricWindowTriple",
14, "WIN_HistoricWindowSegmented",
15, "WIN_HistoricWindowTripleArched",
16, "WIN_W2HorizontalSlide",
17, "WIN_W4HorizontalSlide",
18, "WIN_Curved",
19, "WIN_Bow",
20, "WIN_SplayBay",
21, "WIN_SquareBay",
22, "WIN_Ribbon",
23, "WIN_WSingleHung1",
24, "WIN_WSingleHung2",
25, "WIN_WSingleHung3",
26, "WIN_WDoubleHung1",
27, "WIN_WDoubleHung2",
28, "WIN_WDoubleHung3",
29, "WIN_WRound",
30, "WIN_WOval",
31, "WIN_WMultiside",
32, "WIN_WHalfRound",
33, "WIN_WQuarterRound",
34, "WIN_WPentagon",
35, "WIN_WTriangle",
36, "WIN_WEyebrows",
37, "WIN_WArched",
38, "WIN_WTrapezoid",
39, "WIN_WTrapezoidDoubleSash",
40, "WIN_VentWindow",
41, "WIN_2SashSliding",
42, "WIN_MultisashHorizontal",
43, "WIN_MultisashVertical",
44, "WIN_GlassBlock",
45, "WIN_TerraceDoorSWE",
46, "WIN_W3HorizontalSlide",
47, "WIN_W6HorizontalSlide",
48, "WIN_VentilationBrick",
49, "WIN_Rhomb",
50, "WIN_Skewed",
99, "WIN_Custom",
100,"DOOR_NoSidelight",
101,"DOOR_OneSidelight",
102,"DOOR_TwoSidelight"
VALUES{2} "iWindowClass" 1, "WINCLASS_NORMAL",
2, "WINCLASS_HISTORIC",
3, "WINCLASS_SINGLE_HUNG",
4, "WINCLASS_DOUBLE_HUNG",
5, "WINCLASS_HORIZONTAL_SLIDING",
6, "WINCLASS_SPECIAL",
7, "WINCLASS_DOORSASH",
8, "WINCLASS_MULTISASH",
10, "WINCLASS_SHELL",
99, "WINCLASS_CUSTOM"
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
Solved! Go to Solution.
2026-01-14 12:17 PM - edited 2026-01-14 12:29 PM
Hi Ling,
I think your 'IF' conditions are not as you intend.
You'd need to format them like in this test:
iWindowType = 10
IF 10 <= iWindowType & iWindowType <= 15 then iWindowClass = 2
IF 23 <= iWindowType & iWindowType <= 25 then iWindowClass = 3
IF 26 <= iWindowType & iWindowType <= 28 then iWindowClass = 4
IF 16 <= iWindowType & iWindowType <= 17 then iWindowClass = 5
IF 29 <= iWindowType & iWindowType <= 39 then iWindowClass = 6
IF (45<= iWindowType& iWindowType <= 48) | (100 <= iWindowType & iWindowType <= 102) then iWindowClass = 7
IF 42 <= iWindowType & iWindowType <= 43 then iWindowClass = 8
text2 0, 0, str("%", iWindowClass)
Hope that helps,
Bernd
Edit: As a good exercise for the reader, you can figure out why the 'iWindowClass' was always '8' in the original question.
Explanation:
First let's look at the following code + comments:
x = 9
a = 10 <= x <= 13 ! for x=9 this results in '1.0'! but why?
text2 0, 0, "a: " + str("%", a)
b = 10 <= x ! for x=9 this is 'false' - so b = 0.0
text2 0, 1, "b: " + str("%", b)
c = b <= 13 ! if b=0.0 then this is 'true' - so c=1.0! But even if b=1.0, then c=1.0!!
text2 0, 2, "c: " + str("%", c)
Now looking back at the original post, we see that
will always return '1.0'! The other statements behave the same. (except the last statement with comparison to 99).
That's why the second to last check for iWindowType will always "win" and set iWindowClass=8. The only exception is for iWindowType=99.
Hi Ling,
iWindowType = 10
Hope that helps,
Bernd
Explanation:
x = 9
2026-01-15 02:08 AM
Interpreted as an OR... What is math... Did not even cross my mind...
2026-01-15 06:38 AM
I wouldn't say it's interpreted as an OR. It's more that operator precedence is left to right.
2026-01-15 09:06 AM
Took a bit of messing about with it to get it. So it resolves the left true or false, then uses that result, a 1 or 0, for the following, hence mirroring the equation will always return a 0. That explains your c = b comment, was a bit confused that that.
