rudl
INPUT TEXT I/O will never be -1
Read a lines with Text IO
Input will never be -1 -> infinite loop , no End of file
Part of the script below
aii = OPEN ("TEXT",i_pathnew,"SEPARATOR = '\n',MODE = RO,NEWLINE = LF,FULLPATH")
REPEAT
	IF y # -1 THEN ! BUG will never be -1 , no EOF
		y = INPUT (aii,i,1,a_impb[j][1]) : i=i+1
		y = INPUT (aii,i,1,a_impb[j][2]) : i=i+1
		y = INPUT (aii,i,1,a_impb[j][3]) : i=i+1
	ENDIF
 	j = j+1
	IF i > 40000 THEN
		PRINT "error no EOF"
		END
	ENDIF
UNTIL y = -1 ! ( OR i > 20000) quickfix to limit
3 Replies 3
rudl
Well there seems to be more that doesn't work with the text I/O
and it might be related:
IT finds and reads the file once it seems.
But still throws an error "can't find file" for every view I guess: sections / elevations...
My guess is closing the channel doesn't work?
Maybe i should not have everything in master or try to prevent executing/opening the chanel that often somehow.
But still there is something wrong.
This is on AC 27
Hi rudl,
One issue might be, that you could read past the EOF since you read 3 times before checking if y = -1.
But that's just a quick observation. Haven't tested it.
Best regards,
Bernd
Automating Archicad with Add-Ons, GDL-Objects & Python Archi-XT.com
Jochen Suehlo
Try to use the WHILE .. DO..  ENDWHILE instead of REPEAT, because WHILE checks the condition before it runs through the loop, REPEAT checks it after.
I always used the examples in the GDL Cookbook 3 as a template for my own routines and never had the issues you described.
Jochen Suehlo . AC12-29 . MAC OSX 26 . WIN11
GDL object creation: b-prisma.de
