DGShowModelessDialog wrong number of arguments
Hello everyone.
I need some help here because I've got a quite weird issue with the DGShowModelessDialog function.
Here's the code :
short idPalette;
//Creation of the blank palette (for test purposes)
idPalette = DGCreateBlankPalette(500, 60, DG_DLG_NOGROW, DG_DLG_CLOSE, DG_DLG_TOPCAPTION, DG_DLG_THICKFRAME, ModulePerso_Handler, 0);
//If the creation succeeded
if(idPalette != 0)
				//We start processing events
				DGBeginProcessEvents(idPalette);
				//We show the palette
				DGShowModelessDialog(idPalette);
Then when I build the add-on, I've got 1 error, weird one thought, about :
"DGShowModelessDialog : function doesn't require 1 parameter"
Thought that the function only requires the ID of the previously created blank palette !
Does someone have a clue on this ?
I took a look into the Dialog Manager 2.0 and i don't see where i'm wrong...
Thanks for the help !
2 Replies 2
...when I build the add-on, I've got 1 error, weird one thought, about :
From ArchiCAD 14, the call DGShowModelessDialog requires 2 parameters, although it isn't documented. The second parameter sets the focus for the dialog, e.g. DG_DF_FIRST.
Ralph Wessel BArch
Central Innovation
Oh okay ! Thanks a lot Ralph !
