DWG Export
Hello,
I have seen the question in the FAQ, and seen the example in ACAPI_Command_Call but I am unable to export a dwg in ArchiCAD 9.
My problem stems from not knowing how to find documentation on the DWG addon parameters. My code works fine in version 7 because I read the 'MDCL' help page of which the example is this addon.
Basically I want to use more than just the filename parameter like I did in version 7. Does anyone know how to get the available parameters of an addon, or where this information is published?
The docs say that it should be in the addon folder, but I can not see anything apart from the apx itself.
Thanks,
Adam
0 Replies 0
