ā2018-11-21
10:10 AM
ā2022-10-05
01:29 PM
Daniel Kassai
Solved! Go to Solution.
ā2018-11-21 12:13 PM
Erenford wrote:You're right, this option is not available via the API.
any ideas on what variable corresponds the "Copy construction elements only" on detail marker settings? It doesn't seem to be in the API_DetailType structure.
ā2018-11-21 05:05 PM
ā2018-11-23 03:08 AM
Tibor wrote:Yes please it is important.
How important is this for you? I can add this as a feature request and we can extend the API_DetailType structure for API23.
kzaremba wrote:Yes if its checked it won't copy the 2D elements (dimensions, labels, etc) inside the marker to the detail drawing. If unchecked it will also draw them.
Interesting, I never saw it before. What it is supposed to do? Paste only Core elements?
I test it on an ongoing project and it seems to do nothing![]()
