Archicad C++ API
GS::UniString Does not support Chinese? I have encountered an issue with garbled Chinese characters.
luna
I have tried many methods but have not been successful, and the Chinese characters will become '?' Or some strange symbols.
Please provide me with some ideas, thank you!
2 ACCEPTED SOLUTIONS
Miklos Vegh
Of course UniString supports chinese and other languages also. I think that the problem here is the conversion between utf16 and char types.
I suggest using std::wstring instead of std::string in the code.
UniString can be constructed from utf16 character array with the UniString (const UniChar::Layout* uStr) constructor, so you can convert std::wstring to UniString easily.
UniString supports the 8-bit utf8 characters also if needed.
Miklos Vegh
Or if you have utf8 characters in a file for example, you can construct UniString with this constructor:
char* utf8Chars;
GS::UniString uStr (utf8Chars, CC_UTF8);
6 REPLIES 6
Miklos Vegh
Hi, can you provide an example 🙂
std::string str = "D:/ACFiles/中文测试(Chinese Test)";
such as, how to convert 'str' in the above code to GS:: UniString without garbled characters.
After trying to convert to wstring, it still doesn't work, just starting from ' Transformed into some strange symbols.
Miklos Vegh
I did not compile this code, but I think something like this:
std::wstring wStr = L("中文测试");
GS::UniString uStr (wStr.c_str());
The L() macro forces those characters to compile as utf16.
Miklos Vegh
char* utf8Chars;
Thank you!
I succeeded 🙂
I always thought it was an issue with GS:: UniString, but the problem was that I had previously switched between std:: string and std:: wstring multiple times. xD
Miklos Vegh
