Archicad C++ API
GSHandle to structure [SOLVED]
ReignBough
I have a structure and I saved it on attribute user data using:
API_AttributeUserData user_data;
user_data.dataVersion = MY_ATTS_VERS;
user_data.platformSign = GS::Win_Platform_Sign;
user_data.dataHdl = BMAllocateHandle(sizeof(MyUserData), ALLOCATE_CLEAR, 0);
GSErr ud_err = BMPtrToHandle(&UserData, &user_data.dataHdl, sizeof(MyUserData));
ACAPI_Attribute_SetUserData(&UDHead, &user_data);
UserData is the user data to be saved, and UDHead has the typeID and index.
When I use ACAPI_Attribute_GetUserData(), I am able to get the version and platform sign. But I am lost in retrieving the saved user data.
Help anyone?
>> ArchiCAD 17
~ReignBough~
ARCHICAD 27 INT (since AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
I think it should work this way:
err = ACAPI_Attribute_GetUserData (&attribute.header, &userData);
if (err == NoError) {
	MyUserData** myUserData = reinterpret_cast<MyUserData**> userData.dataHdl;
	// now you can use the userdata
	// after working with it, don't forget to free the handle!
	BMKillHandle (&(userData.dataHdl));
} else {
	ACAPI_WriteReport ("Error: ACAPI_Attribute_GetUserData", false);
Regards,
Tibor
ReignBough
Thanks Tibor.
~ReignBough~
