Archicad C++ API
Get MEP Object type in Add On API C++
Ankur Yadav
I want to identify the MEP object type like whether it's a pipe, duct, bend, cable tray etc. I am getting the library object and properties. How do i identify if an object and library part is of specific type (pipe, duct, bend, cable tray etc). Any link to documentation or code snippet would be helpful.
8 REPLIES 8
kuvbur
You can filter it by API_​ElemVariationID.
Industrial Architect and Structural Design Engineer, developer of free addon for sync GDL param and properties
But it doesn't have classification for MEP elements. I need MEP element identification.
kuvbur
That's right, there is no MEP in the standard list of subtypes, since MEP is not part of Archiсad. All MEP elements are registered with the ACAPI_​Register_​Subtype function and you can look up their API_​ElemVariationID and build a dictionary with constants.
Can we access this type info of library parts using API
No, you need to look up the value in the element's API_​Elem_​Head
But element's API_​Elem_​Head has type set as API_ObjectID for all the MEP library parts. I'm not able to distinguish between them.
Not sure this will help- BUT- since MEP elements are just special Library Parts, they all appear to have a special parameter which distinguishes the MEP version number - currently 4. You could simply create a schedule with lists the Parameter -- "MEP Version" - If the object has that parameter, it is a MEP element, if not, just a object.
If you are confined to a C++ AddOn, you can use the functions of "ACAPI_LibPart_Get to get the part's USID and then use "ACAPI_LibPart_GetParams" to iterate through the parameters to find,or not, the "MEP Version" variable.
A third variant would be to use a simple Python script to return all the parameters of a Library Object, then search though that.  That requires a C++ AddOn in association with the script to return the information. Such a AddOn and sample script is available on my GitHub site, if interested.
By far, the easiest is to just create a schedule and filter the results, but you my have other requirements?
Gerry
API_ObjectID is API_ElemTypeID. Look at API_ElemVariationID, it is part of API_ElemType struct
