Archicad C++ API
Get Survey Point object position via API
Hi!
Are there any means of getting Survey Point object (its position, to be exact) via AC API?
It looks like it isn't possible to distinguish SP between other API_ObjectIDs within a project.
1 REPLY 1
Ralph Wessel
Mentor
Alexander wrote:
Hi!
Take a look at the documentation for ACAPI_LibPart_Search. You can use the function to search for a library part by global unique ID (best) or name. The results include an index referenced by object elements in the model – use this to search for object elements that are instances of a specific library part.
Ralph Wessel BArch
Active Thread Ltd
